OpenLAB issues
Posted: Wed May 04, 2016 7:45 am
without a doubt this is the worse chromatography software I have ever used. A few questions -
1-why does it randomly open different methods when you are processing data.
2-why can you not select a printer before you print
3-why does it default to double sided printing
4-why do you have to keep saving the method, even for simple things like changing the printer?
It seems that Agilent do not get chromatographers involved with their software development. The reporting is just as bad as EZchrom (what was easy about that???)
