MDEA by FID
Hi Folks,
Anyone have experiences with this analysis (lean MDEA by FID)? I need helps to to set up the analysis/method on FID GC.
There is an article on this analysis using GCMS at:
http://www.biochemicaldiagnostics.com/u ... phets.html
You should be able to use their derivitization and chromatographic conditions with an FID.
I believe MDEA stands not for methylene dioxy ethyl amphetamine, but methyl diethanolamine, a tertiary amine, used for gas treatment, probably in addition to some uses.
unfortunately I do not have any experience with GC analysis. But after a very simple google search with "mdea gc analysis", first result hit the nail:
http://www.bre.com/technicalpapers/tech ... enumber=22
Users browsing this forum: Semrush [Bot] and 1 guest
