varian 3800 overflow too high
Posted: Thu Apr 21, 2016 4:59 pm
by kamran biotech
Hi everyone,
New to this forum. I conditioned SPME fiber on standard conditions (1 hour) then changed method to run a blank but my instrument never got ready. message is always NOT READY. I looked up in to manual and one possibility they told "mismatch between the parameters can cause this kind of problem". While looking at the panel on instrument, I have noticed the column flow rate is more than 8 ml/min which should be around 1.
Any suggestions what problem it might be?
Thanks in advance
Kamran
Re: varian 3800 overflow too high
Posted: Fri Apr 22, 2016 7:14 am
by Peter Apps
Welcome to the forum.
Like most new members you overstimate our abilities to troubleshoot by guessing. To make sensible suggestions we need to know what your method and instrument conditions are - in detail.
Posted: Fri Apr 22, 2016 7:15 am
by Peter Apps
Like most new members you overestimate our abilities to troubleshoot by guessing. To make sensible suggestions we need to know what your method and instrument conditions are - in detail.
