Normal Phase Chromatography
Posted: Tue Dec 06, 2005 11:09 pm
I am going to be receiving a normal phase method for analyzing a phosolipid-like analyte. The mobile phase is 2-propanol:hexane:water, 52:40:8, (v/v/v). The column is 3 um, 4.6x33 mm silica gel. I have never run a normal phase method. Are there any special things that I need to consider before I start running this method? My instrument is plumbed with stainless steel tubing so I wouldn't think that the solvents would harm the instrument. Anything else that I should think about?
KarenJ
KarenJ
