Chiral analysis-Normal phase
Posted: Sun Dec 04, 2005 7:52 am
by rc_12321
Why do generally prefer normal phase chromotography for the analysis of chiral purity
Posted: Fri Dec 09, 2005 9:33 am
by gemm
that depends on the polarity of the chiral selector. some vendors have rp columns as well.
but you can run most np chiral columns in "polar organic" mode using high concentration of acetonitrile.
Posted: Sat Dec 10, 2005 11:47 am
by rc_12321
Chiral compounds will have equal physical and chemical properties .Ithink they equal polarity too.
Posted: Mon Dec 12, 2005 9:25 am
by HW Mueller
rc,
you have to have interactions with the stat. phase to get chromatography, if your substance is highly polar you may not have enough interaction with a reverse phase material, etc. So far the situation is the same as for any chromatography. For the separation of enantiomers you make use of physical differences (maybe chem. diffs have been used as well, certainly these are used extensively for separating enantiomers in normal wet chemistry in a pot) that exist toward other chiral material.
