Retention Time of Optical Isomers
Posted: Sat Apr 09, 2016 3:52 pm
Im running an Escitalopram sample via HPLC. However, the standard being used as per USP is the optical isomer "Citalopram". The column to be used is L1 4.6 x 100 mm, 3micron.
Question.
With the above given column specification, would I expect almost the same retention time if I'm going to inject both Optical isomers?
Question.
