Tuning result-water content
Posted: Fri Apr 01, 2016 9:38 am
by ajoyr1986
I am quite new to this field and am in the initial stage of learning and working with a Shimadzu GCMS-QP2010 Plus. The tuning results of the GCMS after turning on the system shows a higher level of water content and typically the water content level decreases with time. However, in this case the system is running for 2 weeks and more and still the water content doesnt seem to decrease. What am I missing and what should I check? Suggestions please.
Re: Tuning result-water content
Posted: Fri Apr 01, 2016 12:14 pm
by dblux_
What is N2 and O2 content ? I hope you post your parameters here.
Posted: Mon Apr 04, 2016 6:56 pm
by James_Ball
I agree, if only water is high that would be strange. If N2, O2, Ar and CO2 are all low but water is high, then either a gas trap is saturated with water or some other component is.
Posted: Tue Apr 26, 2016 3:10 pm
by JMB
"The tuning results of the GCMS after turning on the system shows a higher level of water content....."
1. NEVER shut-down high vacuum equipment (ONLY for maintenance)
2. See 1 above
