Icp organic run plasma problem
Posted: Wed Mar 30, 2016 10:12 pm
I am using a Varian 720 and trying to do an organic run. I am aspirating just primisolv and base oil. I ignite the torch and immediately turn the oxygen on to a flow rate of around 200ml/min to get a green plasma. It stays lit for a few seconds and then goes out. When I check the torch it is very black. I put it in the furnace to clean it and put it back in. Same thing. It was run with the same setup only with out the oxygen so I thought for sure that would fix it but nothing. Any suggestions would be extremely helpful.
Carrier gas is liquid argon dewer.
