what is the best internal standard substance for L-lactate
Posted: Tue Nov 22, 2005 5:51 am
for the requirement of my work, i want to analyze l-lactate in phosphate buffer by HPLC. so my procedure is as follows:
first, add 1mL l-lactate in phosphate buffer solution of certain concentration, then add 15 uL 6N H2SO4. next, add 10mL ethyl acetate to extract and then separate and evaporate. after using pure water to dissolve the residue and filtering the sample, inject the sample into HPLC. (Chiralpak ma+ column, and mobile phase is 1mM Cupric sulfurate : methanol = 9:1, and wavelength is 250 nm)
if i follow the whole procedure without internal standard substance(iss), the reproducibility is not good enough. so i want to choose a proper iss.but i tried acetic acid, propanoic acid, butanoic acid, oxalic acid, and citric acid before, each time i couldn't get good result. i am exhausted.
so i willl really appreciate if someone can give me some suggestion about the internal standard substance of l-lactate or my procedure.
thanks if somebody can help me.
