Width at 50% height calculation on EZchrom Elite 3.3.1
Posted: Tue Mar 22, 2016 8:51 pm
by bstratton
I am trying to get the report to show width at 50% height calculations. I have the width at 50% height calculation column on the report but it is showing 0 for all of the peaks.
Brad
Re: Width at 50% height calculation on EZchrom Elite 3.3.1
Posted: Tue Mar 29, 2016 3:41 pm
by bstratton
I was able to get this to show values on a newer version of EZchrom. Still having trouble where I added that as one of the functions of the report. It show up as a column in the report but all the values are zero. If you add width or height is shows values. None of width at % height shows values other than zero. Just wondering if anyone had info on how to fix this.
Thanks in advance.
Posted: Tue Jun 07, 2016 11:39 am
by Patrick2303
I've the same problem with EZchrom 3.3.2 SP2 (latest version ?)
It's quite strange, once I get it once not at all. It seems that it the same for 'asymmetry'.
Did you find a solution or an explanation ?
Thank you in advance,
Patrick
Posted: Wed Jun 29, 2016 8:08 pm
by varossf
Send me the data file, just one suffices. I can only do it in a newer version of OpenLAB EZCHrom but i can see where it goes wrong.
