Selection of Buffer solution ???
Posted: Thu Nov 17, 2005 8:02 am
My question is what kind of buffer solution will be efficient for seperating bile acids, such as ursodeoxycholic acid, chenodeoxycholic acid, lithocholic acid, cholic acid, deoxycholic acid..., using UV-detector with C18 Column ? I've already tried with phosphate and acetonitrile by gradient method. Am I doing right? Becasuse I found that they have very poor sensitivity at 210nm UV detector.
Any expert's help would be really appriciated. Especillay, detail condition...
Thanks.
Thanks.
