HPLC sterol analyses
Posted: Wed Nov 16, 2005 11:11 pm
Friends,
I have had some frustrating experiences trying to develop a good HPLC procedure for sterol analyses (Sitosterol, stigmasterol, etc). These compound have poor UV absorption, they are difficult to dissolve in aqueous solvents (even when you initially start with 100% organic).
The basic problem, besides the poor UV absorption, is that they have low solubilities in aqueous solvents (H2O+ MeOH, ACN, Acetone, iPrOH, etc) and sometimes require down to 30-50% organic content in the mobile phases in order to be adequately retained in RP columns. This makes MPs and sample solvents not very compatible and results in poor peak shapes.I have not tried normal phase yet.
Can anyone recommend RP columns that could have more retention for these compounds and therefore require higher % organic mobile phases?. This could make the MPs and sample solvents more alike. I have tried Zorbax SB-C18 and Luna C18 (2) columns with some success. Has anyone tried C30 or Hypercarb columns?, Is there anyone with experience using silica columns and Normal Phases MPs?
thanks,
josebenjamin
thanks,
josebenjamin
