High performance UV detectors?
Posted: Fri Nov 11, 2005 9:19 pm
Question: Are there any "high performance" UV detectors out that there are significantly better than the mainstream models available? By better, I mean a 30% or better S/N ratio for peaks that are riding close to the method LOQ, at a typical wavelength of 210 nm. Reason for this is that we have a trace impurity method under development that is close to the goal of a LOQ of 5 ppm, but needs that extra little "push" to build in ruggedness and "safety". We've already run out of all of the usual "tricks" to lower the method LOQ (such as sample concentration, injection volume, fixed wavelength versus diode array, pre-mixing the mobile phase solvents, changing detector slit widths, time constants, flow cells, column and particle size, flow rates, etc, etc.), but would be highly interested to know if there is a unique UV detector out there that is a "superstar" - even if from an obscure vendor.
Thanks.
/posted on behalf of my colleague/
Thanks.
