Effect of solvent on normal phase
Posted: Thu Nov 03, 2005 12:10 pm
by Stephan
Good day
I am sort of new to the world of HPLC, so please forgive me if my question might be trivial...
I am busy with a project, using normal phase HPLC with a RI detector. We work isocratically, using a 3% ethyl acetate solution in n-hexane. Will replacement of the n-hexane with other solvents (like n-pentane or n-heptane) increase the resolution I obtain on the current system?
This seems unlikely to me, and I hope to get a quick and dirty answer before I change the configuration.
Thank you,
Stephan
Posted: Thu Nov 03, 2005 1:36 pm
by DR
Small changes in the amount of Et-Ace should get your peaks to move around. Try that first.
