Misplaced my notes....
Posted: Mon Feb 22, 2016 6:45 pm
(re)-Developing a method and I've misplaced my notes - frankly feeling a bit silly just now , and a bit humbled as I'm usually the "go-to guy" in my lab for things Analytical, as I really should know what I was doing and just cannot seem to either remember what I was doing nor where/what I did with my notes.
Working on separating some problematic peaks. I was calculating an index based on the relative retention time of the constituents against n-heptane:
I've calculated the relative retention times (RRT) of my other peaks: where c = constituent and t = un-adjusted retention time of the peak - standard stuff.
From there I have
I just do not remember where the second equation came from and we've changed the column from DB-FFAP to a Restek-624, along with changing the length and ID, etc; thus, I'm re-developing/validating the methodology (why the change, because management said so... ); therefor, I am certain that the 0.77936 has to be recalculated based on the new column.
I really don't mind looking this information up, I probably need to refresh my memory over the basics. Can anyone please point me toward the text/reference where this is information is located or have I really lost my mind and have something really goofy going here?
I've tried searching my office, my home library, asking my co-workers (yes - they got a little chuckle here, but that's ok, can't remember everything all of the time), and the internet for hours now without so much as a crumb when this site appeared in the Google results - the power of the internet!
TYIA
-z
Code: Select all
(t(c) / t(nhep)) = RRT(c)From there I have
Code: Select all
( 2.5 + (0.77936 - (1-RRT(c)) ) )
of course, (1-RRT(nhep)) = 0I just do not remember where the second equation came from and we've changed the column from DB-FFAP to a Restek-624, along with changing the length and ID, etc; thus, I'm re-developing/validating the methodology (why the change, because management said so... ); therefor, I am certain that the 0.77936 has to be recalculated based on the new column.
TYIA
-z
