Stainless Steel Companies
Posted: Wed Nov 02, 2005 4:07 pm
by adam
Can anyone recommend a company where HPLC column vendors get their stainless steel. I have called a few HPLC column companies but they don't want to give this information out. Didn't have much luck surfing the internet either.
I need to contact a company that makes the steel because I have some questions about the properties of steel that only they could provide.
Thanks in advance. Adam
Posted: Wed Nov 02, 2005 6:20 pm
by DR
I'd look for manufacturers of "precision 316 stainless steel tubing"
Posted: Wed Nov 02, 2005 8:10 pm
by Mark Tracy
Good luck. Even our suppliers don't tell us much. One column hardware vendor says "Germany" the other "Japan."
Posted: Wed Nov 02, 2005 8:16 pm
by SIELC_Tech
Almost all columns are made out of SS 316. You can get content from any SS manufacturer. You can try to contact McMaster-Carr and they will send you a spec for SS 316. I gueas you ale looking for Ni, Cr and other additives
Base on the look of hardware a lot of companies are using Isolation Technologies hardware (at least that’s what they were using originally)). It might be that right now a lot of SS as 100 ft. tubing comes from Asia (or at least the source for SS is Asia)
Vlad
Posted: Thu Nov 03, 2005 2:34 pm
by adam
Thank You!
Isolation Technologies was a hit.
