PE Series 200a Refractive Index Detector
Posted: Mon Feb 22, 2016 4:12 pm
After lamp replacement for the Series 200a RID, what is the procedure to center the new lamp and optimize it? PE Tech Support indicates this must be performed with a new lamp, and that it is a "service only procedure."
Is there a way to reset the lamp hours? Lamp hours indicator is yellow (not green) with over 20,000 hours, but PE Tech Support is not aware of a way to reset the hours.
