relative standard deviation of the calibration line?
Posted: Tue Feb 09, 2016 3:27 pm
I am struggling with one calculation and I am not sure how to solve it. Maybe one of you can help me:
I have applied a weighted linear regression. Now I need to know the relative standard deviation of the regression line sx,y (%).
How do I do it. For calculating relative standard deviation the formula (sd/mean)*100 is used. What about the regression line`?
For example I obtain the below listed results:
Model R R Square Adjusted R Square Std. Error of the Estimate
1 .997 .995 .995 .00673
What should I do with the std error of the estimate? Simply multiply the value *100 or do I need anything else?
Thanke you for your help.
