ChemStation raw data export and individual backgrounds
Posted: Thu Feb 04, 2016 7:49 am
Hi
We have two ChemStation questions (OpenLAB CDS Version Rev C.01.07[27] steering a Agilent GC 7890B) considering raw data export and peak integration. And please forgive if this is too easy, we are newbies on the ChemStation and just cannot find it in the program or reference guide. Our chromatograms are rather easy, as we analyze air for trace gases (N2/O2/Ar in TCD, CH4 in FID, CO2+N2O in ECD), basically our baseline is flat, peaks well separated.
1. Is there an easy way to automatically export detector raw data after each run (of a sequence) as ascii/csv file? (We know that one can "File-Export-CSV..." but this is manual and costs a lot of klicks per detector.)
2. How can the background used for a peak be defined individually? We imagine something as easy as: define a time period of the chromatogram which will be used to determine the background level for each peak individually. As I see it ChemStation detects a peak starting at "A" ending at "B", how can we force it to use the averaged data measured between e.g. "A minus 10 sec" to "A minus 1 sec" as background level?
Thanks for your thoughts!
Best
Michael
Best
Michael
