Presenter: Dr Katerina Mastovska (Covance Laboratories, Greenfield, Indiana, USA)
Date: 16 February, 2016
Time: This event will broadcast live: 10 am EST / 3 pm GMT / 4 pm CET
What Does it Cover?
This webinar will discuss development, optimization and performance of a large LC-MS/MS pesticide multiresidue method for separation of about 450 analytes within 10 minutes. The method uses so called Triggered MRM function, which enables acquisition of additional MS/MS transitions for increased confidence in analyte identification. Acetonitrile extracts (prepared using a QuEChERS-based extraction) are injected directly without a need for a dilution with an aqueous buffer/solution prior to the injection because the LC system employs on-line dilution ensuring excellent peak shape of early eluting (more polar) analytes. The method was validated for routine use in multiple food matrices.
Please register here:
http://view6.workcast.net/register?pak= ... rrer=chrom
Separation Science/Chromatography Forum/
Analytical Training Solutions
david.hills@sepscience.com
