negative y-intercept value
Posted: Thu Jan 28, 2016 10:18 am
Currently performing a linearity study on a related substances HPLC-UV method for a non-UV absorbing molecule. The method uses Nitric acid as mobile phase and a PRP-X100 column; the analyte peaks elute as negative peaks.
A linearity study was performed on concentrations ranging from LOQ (0.1% of spl conc) to 120% of limit concentration (0.28% of sample concentration); this gave a good correlation co-efficient value (> 0.99) however the y-intercept wrt 100% spiked solution obtained was -17%.
A seperate linearity study performed at higher concentrations gave a y-intercept of 0.5%.
It is evident that in this case, the lower the concentrations, the more negative the y-intercept being obtained.
Would appreciate if anyone can give me any pointers with regards to:
- what is the significance of such a low -ve % y-intercept value (-17%)?
- how does this result impact the suitability of the method?
- are there any suggested modifications that can be done to the method to improve the y-intercept? The sample concentration cannot be altered since it is the highest possible concentration to give an adequate S/N ratio at LOQ concentration, while maintaining an adequate specificity between the main peak and other known impurities in the test solution.
