Issues connecting an HP1050 79853c using an NI GPIB card
Posted: Tue Jan 26, 2016 6:49 pm
Hi Everyone,
I have been working to get an old HP1050 VWD to read on NI MAX using an NI IEEE GPIB card and have been able to "see" the instrument but shows 30 different instruments connected to the card. Some don't respond to the idn query and others do but send out garbage data. I have tried installing chemstation 6.0.3 but from seeing the io library config, I suspect that I can only use specific HP-IB cards to communicate with the instrument. I have also tried installing various io library suites but the same communication issues occur as in NI MAX. Has anyone been able to successfully connect and communicate with the HP 1050 to get an output voltage for absorbance units? Any help will be much appreciated!!!!
