Eur. Ph. Castor oil identification with GC-FID
Posted: Fri Jan 15, 2016 6:49 pm
Hi all!
Basically, I analyze essential and fatty oils (raw material) for pharmaceutical use, using GC-FID equipment and European Pharmacopoeia methods.
My equipment is Agilent GC 7820A with autosampler Agilent G4513A.
And I have some problems with Castor oil (virgin) identification C: identification of fatty acids (method number 01/2013:0051).
In method is written that I need to correct peak by multiplying it by a correction factor, that I calculate from the result of Reference solution analysis.
But i fact, the result of analysis that gave me my ChemStation, automatically calculating content percentage (program is not taking in account solvent peak), is closer to analysis result that gave us company manufacturer.
For example last Castor oil component percentage was:
company manufacturer analisys results:
-palmitic acid - 1.2%
-stearic acid - 1.4%
-oleic acid and isomers - 3.8%
-linoleic acid - 5.0%
-linolenic acid - 0.5%
-eicosenoic acid - 0.3%
-ricinoleic acid - 87.4%
-any other fatty acid - 0.4%
from ChemStation (automatical calculation)
-palmitic acid - 1.1%
-stearic acid - 1.3%
-oleic acid and isomers - 3.6%
-linoleic acid - 4.6%
-linolenic acid - 0.4%
-ricinoleic acid - 88.1%
-any other fatty acid - 0.5%
with correction:
-palmitic acid - 1.0%
-stearic acid - 1.1%
-oleic acid and isomers - 3.1%
-linoleic acid - 3.9%
-ricinoleic acid - 89.8%
Correction factor is 1.19.
Why could such big difference appeared between company manufacturer results and my with correction?
And what peak I need to multiply by correction factor, all?
Cheers,
Dmitrij
with correction:
Cheers,
Dmitrij
