interpreting odd low resolution(?) smushed(?) ESI-MS peaks
Posted: Mon Jan 04, 2016 6:31 am
I'm looking at four hexapeptides. Crystallized monomers are in a dH20 solution (where they self aggregate) and are analyzed using ESI-MS (Finnigan LTQ, Thermo-Scientific). I first look at the full mass spectrum and then to look at each oligomer I use a function of the LTQ software called ultrazoom which is basically a high resolution scan of a small specified range.
The lower oligomers display very distinct peaks, but at the higher oligomers every other m/z complex seems to display this very odd round hill type shape
I don't quite understand what is happening. The only thing I can think of is that there are mobile protons so each peak is less distinct.
I don't even know how to search for this phenomenon in the literature as I don't know what it's called
Would really appreciate some help pointing me in the right direction
