Headspace analysis of tolueen in unleaded gasoline
Posted: Sat Dec 19, 2015 10:32 am
Hi I am a student in the Netherlands. I am studing at the Hogeschool Leiden (Uneverity of aplied sience Leiden).
The current project where i worked on is the GC analysis of toluene in gasoline with headspace on a Trace 1300GC with the FID detector.
I take 3,5mL of gasoline and put it in a 5,0 mL vial and 200µL N-butylformate as a internal standard.
This is headed for a houre in a waterbath at 60 dagree celcius.
Than there get 5µL of the headspace injected, the method was the same as http://www.restek.com/chromatogram/view/GC_PC01071 but the colum was the Rtx 5 ms, 30 meter.
The chromatograms are good but when the same sample is injected multiple times, and corrected with the internal standard, the corrected area of al the peaks are difrent, even the rates of the peaks are diffrent.
My teacher doesn't know how to get stable peak rates and the only thing i could find on the internet and some books was the use of a headspace autosampler, but we haven't one so this is not a solution, what else coold i try?
