No Reproducable RESULTS
Posted: Mon Dec 14, 2015 6:51 am
We have Sykam HPLC system with PDA detector and Gradient pump. We have problem with the repeatability of samples results. aftre injecting many samples with same concentration we found the peak area different for all samples even the retention time is same. what may be the possible cause of the non reproducable results.
thanking you
thanking you
