Weighing cold reagents for EP determ. of ethylene oxide
Posted: Thu Dec 10, 2015 5:29 pm
I am running EurPharm method 2.4.25, ethylene oxide and dioxan. The method states, "Weigh 1.00 g of cold ethylene oxide stock solution (this is in PEG200) into a cold flask containing 40.0 g of cold polyethylene glycol (PEG) 200". Does anyone have experience with this method or weighing cold reagents into a cold flask? I've always heard you should weigh at room temperature. This is a standard prep so accuracy is critical. Any tips would be appreciated.
