Chemstation 6890 Parameters Changing
Posted: Wed Dec 02, 2015 6:50 pm
Hi all,
We have latest chemstation with Open lab. I have a 6890 that is what seems like randomly changing the front column parameters. The actual column length is 30m but it will change to 15m on the panel. The method has 30m specified. I have to manually update the column length to 30m from the panel through the config button. I sometimes see the error "method changed by new user" when I am logged in as Admin. We had to disconnect the GC from the network to do some maintenance on it recently. It had to go into the shop for repair, I am wondering if a communication setting was changed during maintenance performing qc checks on it with their computer/chemstation or from the panel. Any thoughts or experience with this issue is appreciated.
