AMDIS: Disqualifying library hits based on retention time
Posted: Wed Dec 02, 2015 5:54 pm
Hi all,
I'm sad to report I'm having a bit of trouble with AMDIS. I have a library of compounds I'd like it to search, but some of them are spectrally similar, and as a result, the software is mis-reporting. To solve this, I've incorporated retention time information into each library entry:
And I've instructed the software to qualify hits based on retention time, with a 0.2 min RT window, and a 100 point penalty to any and all compounds falling outside of that window:
...but no matter what I do, the software insists on applying (at most) a -12.3 correction based on retention time. Take note of the following image, where a peak eluting at 10.13 minutes is being identified as the library compound with a retention time of 9.44 minutes. This is well outside the 0.2 minute RT window, yet the compound is not being penalized to the extent I would like it to be.
I need to take this library and these settings and use them to run a batch job on ~500 chromatograms. The results will then be subject to chemometric statistical analysis, so it's very important that problems like this not be allowed to crop up, or else the whole entire study might be thrown off. Can anyone please advise me on how to correct this? I would like it to immediately disqualify any library hit that falls outside of 0.2 minutes from the expected value.
Thanks!
Thanks!
