Thermo trace ... No heating of,the ion source
Posted: Fri Nov 27, 2015 5:07 pm
by KevinBe
Dear all,
I cleaned for the first time my ion source by myself and I had to replace the heating board by a new one.
Unfortunately when I put everything back in place, it still does not heat... What could be the problem? I double checked the connection and everything is ok. Also the hardware test shows that everything is ok but the heating...
Is there a way to check if the heating is working without having to,put everything under vacuum again?
Any idea what the problem could be ?
Thanks a lot,
Kevin
Re: Thermo trace ... No heating of,the ion source
Posted: Fri Nov 27, 2015 5:18 pm
by KevinBe
Now that I think: if the fuse is out of work, would it show it in the tune tests? Or would I have to check it myself?
