Tools.mac not working anymore on Chemstation C.01.06
Posted: Tue Nov 24, 2015 4:45 pm
Hi all.
I installed tools.mac from my software install disk into my offline version of Chemstation and then called it using the macro tools.mac command line call.
It worked nicely for a bit and then when I was looking through and trying out the other loaded tools something happened and the spectra tool for min/max spectra is not working leaving just the UV spectra curve with no annotation as to min and max spectra.
Is it possible to reset chemstation in so far as the macro tools go? Or should I do something else? Any help is greatly appreciated.
Regards
Regards
