Connector to be used on D to A board of Dionex CD20 detector
Posted: Mon Nov 23, 2015 4:59 pm
by rickaustin
I have a Dionex CD20 detector. I want to use a strip chart recorder for the output using the Digital to Analog Converter output on the card in Slot 2. I believe the top two pins will be what I need (of the 10 pin connections). I would like to make a cable - does anyone know the specifications of the plug I would need to buy for the cable end?
