linearity test - GC method
Posted: Fri Nov 20, 2015 8:04 pm
Hi
I calibrated GC for Ethylene impurities with calibration blend of hydrocarbon impurities in Ethylene balance. I used two standards(with concentration other than that used for calibration) to check its linearity and calculated R2 including Zero as third point.
Is two level linearity check is acceptable for method validation.
Please suggest most accurate method to dilute hydrocarbon gas blend.
Thanks in advance.
Thanks in advance.
