Waters 1525 binary pump in Masslynx 4.1
Posted: Wed Nov 18, 2015 10:22 pm
I am trying to set up a Waters 1525 binary pump under Masslynx 4.1. I tried connect to the pump using an Agilent GPIB card as well as a NI GPIB card, but i couldn't get a connection with either of them.
(Couldn't find the Instruments using the IO Softwares!) I set the pump to different GPIB adresses but had no luck with that as well.
Is it possible to connect the 1525 pumps using an Agilent GPIB card? We have a spare one availabe whereas the NI GPIB card is normally used in another setup.
I can't find the right pump when configuring the inlet devices in Masslynx 4.1, there is no 1525 pump available. Are there special drivers i have to install first?
Has anybody suffered from the same problems?
Cheers
Bastian
Cheers
Bastian
