Dionex PDA-100 acting up
Posted: Wed Nov 18, 2015 12:41 pm
Hello
I've reactivated the HPLC in our lab a couple of months ago; while it had not been in use for a very long time, I got the whole setup working relatively quickly, and it has been used since every now and then by myself and a couple other people.
However, the other day, some time during equilibration, the detector started behaving downright weird, since that time constantly producing error messages for both the deuterium and tungsten lamps in Chromeleon, as well as for the little automatic test sequence it runs on startup (power LED flashing). I've disassembled and checked the parts accessible via front panel and everything seems fine, no leaks, no loose plugs or anything. The lamps seem fine, too, and are supposed to have a couple hundred hours of lifetime left each according to the Chromeleon log. As per the manual, I've flushed the cell to make sure it's not just air bubbles in the cell making the wavelength match on startup fail.
Whenever I try to control something from Chromeleon, the Audit Trail tells me the detector's already running an autozero command; this makes me think the instrument's stuck in some sort of loop - is there any way to perform a hard reset?
I'd appreciate any help and apologize if this is a stupidly simple issue to resolve to all you experts. I have no prior experience with HPLC instrumentation and am basically just getting by on manuals. It's been a long time since anyone's even been responsible for the setup, so there's no one around anymore who knows how to troubleshoot something like that.
Regards
Daniel
Regards
Daniel
