White Fuzz On The Fittings
Posted: Mon Oct 17, 2005 12:47 am
by syx
Dear Members,
What is the source of white fuzz on the fitting? Is it due to capillary leakage of the fittings?
Siswanto Tanuatmojo
Posted: Mon Oct 17, 2005 1:26 am
by tom jupille
Possibly. Could also be due to a little bit of residual buffer left behind when you assembled the fitting.
Re: White Fuzz On The Fittings
Posted: Mon Oct 17, 2005 7:50 am
by amaryl
Dear Members,
Siswanto Tanuatmojo
is it precipitation of buffer salt or an indication of more concentration of buffer?
regards
amaryl
Posted: Tue Oct 18, 2005 7:54 am
by syx
Will it be a problem? Any suggestion for corrective action if it is caused by capillary leakage that may be cannot be seen?
Posted: Tue Oct 18, 2005 12:46 pm
by tom jupille
As long as you don't see any visible moisture/fluid, I wouldn't worry about it. Any leakage is probably measured in nL/day.
