injection from Agilentchemistation vs actual injected
Posted: Fri Nov 13, 2015 1:54 pm
Hi all,
I am new in the GC, I am using the GC 6980 and the software Chemistation from Agilent.
In my setting from Chemistation software i set the injection amount is 1 ul (using 10 ul syringe), howewer I always observed that the syringe in the front injector takes "different amount" (i am not really sure if it is different because I saw the level from the barrel)
i am wondering if something wrong or it is the way machine setting up.
For instance:
if I set 1 ul > syringe pump 3 times and i see 2ul level in barrel
if i set 2ul > the syringe pumps 4 times and I see 3 ul level in barrel
Thank you
For instance:
Thank you
