Co-elution problem for GC-MS
Posted: Thu Nov 12, 2015 9:35 am
I have been using GC-MS for identification and quantification of organic acids in human urine. I have used C13 labelled Myristic acid as an internal standard and it elutes at 28.5 min while the total run time was 38 min. I have run a few organic acid standards for which the results were fine. Then i have run a sample of urine and citric acid is found to co-elute with Internal satndard which generally leads to increase in peak area and hence not useful for quantification. Is there a way to resolve this issue because there are a lot urinary metabolites which elute almost till 33 min and the retention times are very close. Thanks in advance for your inputs.
