AKTA explorer pH problems
Posted: Tue Nov 03, 2015 10:44 pm
I am trying to run a 10mL protein G column on the AKTA explorer. The load was not binding to the column correctly and I realized the pH seemed really high (~10). I ran PBS (checked the pH of the bottle and it was ~7) over the column and it took 50mL (5CV) to get to pH 7.
Trying to troubleshoot, I am now running PBS through the column bypass position to try and figure out where the high pH is coming from. Like I said, I checked the pH of the PBS buffer and it is correct at 7. It is running through A11. The only other A1 buffers are ethanol and a low pH washing buffer. Still, the buffer that is coming out of A pump is at pH 9.
The system is really old and the only thing I can think is that there is something in the lines that's raising the pH. I really have no good logical eplanation of how this pH 7 buffer could suddenly be pH 10.
