Varian/Bruker GC450 failure after long shutdown
Posted: Mon Nov 02, 2015 2:20 pm
Hi all
If you have a Varian/Bruker GC450 that has been shut down for a long time, when you start it up it may show a blank grey screen with the status lights cycling continuously.
If this happens to you, change the 3V coin battery on the main circuit board inside the left side panel and all will be as good as new.
