Plunger seal vs. Rinse seal
Posted: Wed Oct 28, 2015 3:34 pm
by sepr8tr
We have a Shimadzu LC-10ATvp and need to replace both the plunger seal and the rinse seal. I am wonder what the difference is between these two items because they are very similar in appearance.
Re: Plunger seal vs. Rinse seal
Posted: Wed Nov 04, 2015 7:37 pm
by elsico
Different color?) Very poor pictures in manual so i'm not sure which is plunger.
But normally black one is plunger seal.
Posted: Thu Nov 12, 2015 3:23 am
by Alfred88
Hi.
I have serviced the Shimadzu HPLC for >10 years. The plunger seal (black/yellow) and back seal (white) are almost the same. However, the back seal is not strong as the plunger seal.
Do you want to use motor oil (color code yellow) as a substitute for antifreeze (color code green)?
Note: I do not work for Shimadzu.
Alfred
