Repeatability problems
Posted: Tue Oct 27, 2015 5:12 pm
I'm devolping a method to detect simultaneous six pesticides (metaldehyde, metazachlor, propyzamide, pendimethalin, carbetamide and quinmerac) by LC-ESI-MS, using MRM (2 transitions).
Equipment:
Alliance 2695 (LC)
Quattro premier XE (MS)
Solvents:
UpH2O + 0.1% AcOH
Methanol + 0.1% AcOH
The elution seems pretty ok!
I'm injecting x10 from the same vial 50uL of 10ug/L pesticides mix and the precision is about 70-75%, for all pesticides.
Example:
Injection 1 - Metaldehyde area = 68766.26
Injection 2 - Metaldehyde area = 31420.48
Injection 3 - Metaldehyde area = 63153.2
Injection 4 - Metaldehyde area = 43335.82
"Narrow the problem"
LC
I already change the syringe for a new one, performed the adjusting seal, needle wash, primed the solvents lines, changes the solvents......but the repeatability "saga" continues....
MS
Clean cone, check the baseline noise (Ok, done that with Waters support!), but the repeatability "saga" continues....
Any ideas?
Equipment:
Alliance 2695 (LC)
Solvents:
UpH2O + 0.1% AcOH
Example:
LC
MS
Any ideas?
