Difference in Gas chromatography and column chromatography
Posted: Fri Oct 23, 2015 8:34 am
by chance.lee
What is the difference between Gas chromatography and column chromatography? Or they are similar to each other? :?
Please, any recommendation would be very welcome. Thank you!
Re: Difference in Gas chromatography and column chromatograp
Posted: Fri Oct 23, 2015 4:16 pm
by GOM
Hi
The use of the word column can be confusing to a newcomer - a column implies a large vertical cylindrical solid or tube. It and other terms (like theoretical plates)come from an historical connection to large and small scale distillation and separation columns ( or tubes).
So a column in chromatography terms is basically a tube - it can be glass,metal or very thin coiled fused silica tubing with a filling or internal coating that separates a mixture as it is made to pass through it.
In gas (column ) chromatography a gas is used to transport the mixture through the tube and in liquid (column) chromatography a liquid is used.
So column chromatography uses a tube (or column) and gas chromatography is a form of column chromatography.
Does that help?
Does anybody else have a more helpful explanation?
http://www.itjustabox.com might help
"Up to now, we have learned with much effort to distill, crystallize and recrystallise, and now they come along and just pour the stuff through a little tube!" Nobel Laureate Heinrich Wieland.
Cheers
Ralph
Posted: Fri Oct 23, 2015 9:49 pm
by tom jupille
These days, the term "column chromatography" is generally applied to liquid chromatography in glass tubes (columns) under gravity flow (or low-pressure pumps such as peristaltic pumps).
There are lots of ways to subdivide, but one way starts with the mobile phase: liquid or gas.
Then the physical format:
- column chromatography (low pressure)
- high performance liquid chromatography (HPLC) high pressure
- paper chromatography (a sheet of filter paper, with liquid flow by capillarity)
- thin-layer chromatography (a thin layer on a plate, with liquid flow by capillarity)
Gas chromatography
- packed-column (small particles packed in a tube)
- capillary (long capillary tubes with stuff on the inner wall)
And yes, there is overlap! :wink:
Posted: Tue Oct 27, 2015 3:11 am
by MandySwift
Generally, column chromatography is much more efficient in cost.
Posted: Tue Oct 27, 2015 8:57 am
by chance.lee
Thanks a lot for all of your reply!! :D
