Trouble separating Lipids
Posted: Wed Oct 21, 2015 1:01 pm
Hey there,
I am really stuck with a problem here that drives me crazy!
So: I got a SOP from another group where they separate DPPC, DSPE-PEG and Cholesterol using a C18 (Acquity, 1,7µm, 2.1x50mm) column coupled to a CAD-detector.
They use 80% and 100% MeOH with 0,1% Et3N and the program is a follows: 80% MeOH for 1 minute, 100% MeOH for 8 minutes, another 5 minutes of 80%MeOH @ 0,2mL/min @ 50°C.
Thing is: The substances are only soluble in 100% MeOH and I need to inject them in 100% methanol.
I am using a 1260 from agilent and even bought a new column which I hoped would fit my needs: MN Nucelodur Isis, 3µm, ID 3mm, length 250mm.
I cannot use the program from the SOP because I don't have a CAD, we're only using a DAD (which is useless in this case) and an RID which means I can only run in isocratic mode (80% MeOH).
I tried injecting the 4µL they propose in their SOP (using a manual injector and build a loop from a peek capillary), tried 20µL, tried even 200µL but it seems that I only get one big peak everytime (probably the 100% MeOH?) no matter what substance I inject.
I tried to lower the temperature to 10°C and raising it to 50°C. I am running @ 0,2mL/min @ ~200 bar.
Should I try even more columns? The C8, C18 and MN Sphinx also gets me the same results. Could HILIC be an option? Is an RID the wrong detector? Besides: I can't go less then 80% MeOH, the stuff will just precipitate (and I can't heat up the injector). Injecting it in 80% MeOH also doesn't do the trick.
I am really desperate right now as we want to measure the lipid content of liposomes.
I hope somebody has some ideas I could try!!
Best regards
Marek
I am now trying for
Best regards
Marek
I am now trying for
