EPA method 552.3
Posted: Wed Oct 14, 2015 2:33 pm
by haslani
Hi All, I am trying to calibrate my GC for DBAA, I injected it to find the exact RT and after that I prepared standard series. The problem is that the GC showed same responses for all concentrations prepared. Do any one has any idea about solving this problem?
Re: EPA method 552.3
Posted: Wed Oct 14, 2015 2:39 pm
by Peter Apps
The peak that you think is DBAA (whatever that is) is actually a solvent impurity. Try with a different solvent. What is your expected (from literature or application note) retention and what retention do you get ? Are you using identical operating conditions to the literature method ?
Posted: Wed Oct 14, 2015 5:44 pm
by Bigbear
Are you seeing the same thing for your other column?
