CTC Combipal stripey screen of death
Posted: Fri Oct 02, 2015 11:26 am
by Peter Apps
Hello All
I have just restarted a CTC Combipal after not using it for several months, and the controller terminal screen shows green stripes on a black background, and then green stripes obliterating most of the text on subsequent screens. As far as I can tell from the little bit that I can see the scroll wheel and buttons are functioning correctly.
Has anyone seen this, were you able to fix it, and how ?
I have e-mailed CTC also.
Re: CTC Combipal stripey screen of death
Posted: Mon Oct 05, 2015 7:27 am
by Forse
I have had the same problem.
Refurb of the LCD display is the way to go, or you can just ignore it if you controll the machine from a computer.
We had a local service provider do it, but I'm shure CTC can do it to.
Posted: Mon Oct 05, 2015 8:09 am
by Peter Apps
Thanks Forse.
I am waiting for a price for a replacement screen - unfortunately the instrument that the sampler is currently on does not have the control software. Manual injections will serve in the meantime.
Posted: Mon Oct 05, 2015 8:18 am
by Forse
You'r welcome.
I don't know how the screen is attached to the circuitboard. It may be soldered, but if you'r good with a soldering iron it's probably easy to fix.
Else I think most places that refurb LCD screens can do the repair. I know LCD screens are often repaired in the car industry, so maybe it is easier to find a solution in that industry.
Posted: Wed Oct 14, 2015 6:23 pm
by Yama001
That screen failed on us several times a few years back. The replacement was around of $500 USD.
Posted: Thu Oct 15, 2015 6:15 am
by Peter Apps
Running at close to $1000 now !
Posted: Sun Oct 18, 2015 5:07 pm
by uzman
Most LCDs have a ribbon cable for communication , and sometimes they loose contact with their socket.
If you can disassemble the panel and reach LCD , you may try to push the cable into the socket , or a little move back or forth may solve the problem.
Posted: Sun Oct 18, 2015 6:01 pm
by Peter Apps
Thanks uzman, I've tried that, and a few other things to no avail.
