Autoextraction Woes
Posted: Fri Sep 25, 2015 12:36 pm
by Bigbear
I use a very old floppy driven Autotrace SPE extractor. Yesterday it would not read the only disk containing my extraction method. Yes my bad for not making a backup!
The software to create disks does not seem to work.
Is there anyone out there still using this dated technology that could help me?
Bear
Re: Autoextraction Woes
Posted: Fri Sep 25, 2015 2:36 pm
by Steve Reimer
Does the floppy drive work at all?
Posted: Fri Sep 25, 2015 4:43 pm
by DR
It's more likely the drive than the disk...
Posted: Fri Sep 25, 2015 8:37 pm
by Steve Reimer
The drive may be replaceable if you know someone with old computer parts.
Posted: Mon Sep 28, 2015 3:44 pm
by rb6banjo
Is the computer so old that it doesn't have USB ports? I have recently had good luck with a USB floppy drive for transferring data between systems.
Posted: Tue Sep 29, 2015 10:54 am
by Bigbear
The Autotrace is ok, as other program disks run.
I messed with the software and stumbled on the way to create disks. I programed 2!!!!!!! Now to test them to see if they work as the old one.
