Cannot tune, large leak.
Posted: Mon Sep 14, 2015 4:54 pm
About a month ago after a He tank swap, I had a large leak that was very difficult to find because my system seemed air tight. Detector and column (Agilent 5975c) did not contain the leak but as soon as the headspace and GC were hooked up the system couldn't even pass and air and water check. It turned out a Swagelock fitting extending the GC control line to the headspace supply port was leaky. Once I replaced it my leak symptoms disappeared.
The tank was recently changed and immediately afterward I am getting the same kind of response as before, a large leak but my inlet is pressurized and headspace working normally. The fitting I replaced is fine, so now my thinking is that the EPC is leaking because my headspace is detecting Nitrogen.
Has anyone else experienced a leak like this? My next step is to rewire the GC to be used without the headspace but if this sounds like an EPC failure to anyone then I can just order a replacement instead of doing major work just for diagnosing.
Thanks!
Thanks!
