Which is best: Thermo ISQ or Shimadzu QP2010Ultra?
Posted: Thu Sep 10, 2015 2:22 pm
Dear all, I am about to buy a new single quadrupole GC/MS and I am still undecided between a Thermo ISQ or a Shimadzu QP2010Ultra. Price for both is the same, autosampler also (combipal AOC 6000). Software is GCMSSolutions on Shimadzu and XCalibur on Thermo.
One feature that attracted me on the Thermo is the included vacuum interlock system so that I could change from an EI to a PCI source without having to vent the system, and changing the source in general seemed a lot easier on the Thermo than on the Shimadzu (for me it would be important to be able to switch easily between EI and PCI). Service for both I heard is quite good over here, so that should be about the same. Other thing I was wondering about is the reliability and robustness of both machines. Anybody any experience? Finally, the Thermo ISQ could also be made to work together with Cerno Massworks to do more accurate mass measurements (100-1000 x better than nominal, or so I heard), thereby allowing formula ID. With Shimadzu they are still trying to implement the feature to record data in profile mode - will be included in the next software update apparently, but right now it's still untested. Anybody any experience by any chance with using Cerno Massworks with Thermo ISQ data? Does it work? (in my application it would be to measure the mass of the molecular ion more accurately in PCI mode and try to determine the molecular formula to help with compound identification)
