Needle Home Z error code
Posted: Thu Sep 03, 2015 1:08 pm
We are using a Shimadzu Nexera X2 SIL-30AC MP autosampler and yesterday a tray got placed improperly causing a misinjection.
Ever since then we have a 'SIL ERR NDLE HOME Z' error so we know it is not properly resetting to it's home Z position on power up.
We have been able to clear the error..but then it still does not reset to home position and when we try to start a run the error occurs again.
We have replaced the syringe, tried full reboots, power downs, and even unplugging the instruments (controller, pumps, and autosampler) before powering back up.
We get full network reconnectivity with its controller and computer (which also got power cycled).
You can hear a grinding sound when it tries to reset to home but doesn't move. When moving by hand though it moves freely.
Anyone have any idea where we can proceed from here?
::Update:: This morning I have gone in while it is turned off and manually turned the belt drive cog to lower the syringe almost all the way to the bottom. Now when it turns on and tries to home it raises the syringe back up but does not grind anymore. But it still errors with Needle Home Z right after it finishes raising the syringe.
Thanks for help and suggestions,
KDM
KDM
